Using Plugins
IBM Player SDK version 1.1.0 introduced a plugin system which enables you to extend the media player with additional features.
Plugins will be provided by IBM and must be provided during player initialization in UstreamPlayer.initWithContent(ContentDescriptor, MediaPlayerModule).
These extensions may require different player views than tv.ustream.player.android.PlayerView. PlayerView requirements for a plugin will always be stated
in this documentation but can also be queried from the MediaPlayerModule instance itself using MediaPlayerModule.getSupportedPlayerViewType().
Make sure to always use the appropriate PlayerView.
Creation of the plugin is the user’s responsibility, use the constructor of the desired plugin, provide appropriate parameters and set listeners.
When a plugin is passed to a UstreamPlayer instance it will be retained across configuration changes, however the listeners the user provided are not subject
to the usual UstreamPlayer.attach() / UstreamPlayer.detach() working. The user needs to manually set and remove those listeners.
The current MediaPlayerModule in use can be retrieved from the player instance using UstreamPlayer.getMediaPlayerPlugin() which returns
a MediaPlayerModule that will be cast to the appropriate class that was set during initWithContent. The user must know which MediaPlayerModule was
set during init.
Please note that while a MediaPlayerPlugin provided through UstreamPlayer.initWithContent is retained across configuration changes,
the plugin itself might NOT support configuration changes at all due to plugin specific reasons. This will always be stated in the plugin’s documentation
under the Plugin limitations section.
Ads Plugin
IBM Player SDK version 1.1.0 introduced Ads Plugin (called AdsMediaPlayerModuleAndroid) which can be used to provide ads for the audience using the developer’s
Double Click for Publishers account.
Supported features:
- Pre-roll video ads
- Mid-roll video ads with multiple configurable scheduling via
AdScheduleRules - Customizable ad parameters via key/value pairs
Ads plugin needs to be instantiated and passed to the UstreamPlayer instance via initWithContent(ContentDescriptor, MediaPlayerModule).
Upon plugin creation the user can provide the following configuration data: String dfpTagUrl, AdScheduleRule scheduleRule,
where dfpTagUrl points to the user’s Double Click for Publishers account and adScheduleRule is the class defining when to show ads.
See javadoc for details.
Additionally, any time after creation the user can set:
- an
AdStateListenerusingAdsMediaPlayerModuleAndroid.setAdStateListener(AdStateListener)which notifies the user when an ad is being displayed. AdDatawhich is targeting metadata for DFP. Feel free to use your own meta and/or meta provided byMetaDataListener.onMetaData(MetaData).
Example usage
Add the Ads Plugin to your build use same local m2 repository in project root folder and add these lines to your gradle file (Google IMA SDK is a dependency of the Ads Plugin):
implementation 'tv.ustream.player:ibm-player-sdk-android-plugin-ads-external:1.4.0@aar'implementation 'com.google.ads.interactivemedia.v3:interactivemedia:3.11.3'implementation 'com.google.android.gms:play-services-ads-identifier:17.0.0'implementation 'androidx.browser:browser:1.0.0'
In AndroidManifest.xml set configChanges settings in the player activity as:
<activityandroid:name="com.my.company.PlayerActivity"android:configChanges="orientation|screenSize|keyboardHidden"android:label="@string/app_name" />
Create a UstreamPlayer as usual, but provide an AdsMediaPlayerModule at init:
ustreamPlayer = ustreamPlayerFactory.createUstreamPlayer(playerId);if (!ustreamPlayer.isInitialized()) {final AdScheduleRule scheduleRule = new FixedIntervalRule(true, 60000); // Schedules a pre-roll and inserts mid-rolls after 60 seconds of playback timeustreamPlayer.initWithContent(contentDescriptor, new AdsMediaPlayerModuleAndroid(/* AdsStateListener */this, DFP_TAG_URL, scheduleRule));}
In your application’s layout file use tv.ustream.player.android.plugin.ads.AdsPlayerView (instead of regular tv.ustream.player.android.PlayerView).
<FrameLayout xmlns:android="http://schemas.android.com/apk/res/android"android:layout_width="match_parent"android:layout_height="match_parent"android:background="@android:color/black"><tv.ustream.player.android.plugin.ads.AdsPlayerViewandroid:id="@+id/playerview"android:layout_height="match_parent"android:layout_width="match_parent"
Retrieve the plugin after init:
AdsMediaPlayerModuleAndroid mediaPlayerPlugin = ustreamPlayer.getMediaPlayerPlugin();
Set an AdsStateListener on the plugin:
mediaPlayerPlugin.setAdStateListener(new AdStateListener() {@Overridepublic void adStarted() {// Customize UI elements during ad playback, e.g: hide seekbarseekBar.setVisibility(View.INVISIBLE);muteToggleButton.setVisibility(View.INVISIBLE);fullScreenToggleButton.setVisibility(View.INVISIBLE);}
Set meta for DFP using an AdData object:
List<String> adKeywords = Arrays.asList("testKeyword1", "testKeyword2");Map<String, String> adExtras = new HashMap<>();adExtras.put("adExtraKey1", "adExtraValue1");adExtras.put("adExtraKey2", "adExtraValue2");AdData adData = new AdData("TestTitle", adKeywords, adExtras);mediaPlayerPlugin.setAdData(adData);
Everything else works just like it did before, no other code modification is required.
Plugin limitations
- Ads Plugin does not support configuration changes, use
android:configChanges="orientation|screenSize|keyboardHidden"in your player activity. This limitations is imposed by Google IMA SDK on which we depend to show ads. - Ads Plugin uses it’s own PlayerView:
tv.ustream.player.android.plugin.ads.AdsPlayerView - Seeking while an ad is playing will seek the original content, as ad seeking is not possible
